lower control arms
I saw on rev-auto some lower control arms that are supposed to reduce camber. I wanted to see if anybody has those and can tell me if they work or if there is any other company out there who makes lowere control arms to reduce camber.
topic has been covered… try searching…
SPC
Megan Racing
Function 7
Wicked
and many more…
and yes it does reduce negative camber so long that your vehicle is dropped already
i have the megan racing ones, no they don’t reduce camber. they’re the same exact size as stock.
some of the other brands might though?
So what’s wrong with the SPC Rear Camber Kit?
nothings wrong with spc camber kit… i have spc LCAs theyre pimp… and mine are shorter than stock by a little under an inch or so…
But it narrows the rear width, why would you want to do that?
to save your tires and set your camber to whatever settings you want.
Yeah, but the same adjustments are accomplished with adjustable upper control arms and you’re not screwing with the width.
chsscott- you can drop it more with larger/wider tires, and still correct camber without your tires rubbing the inner fender.
