I was servicing my brakes and I noticed that my driver side springs are loose? My car was on the hoist and I can move my springs… Is there something wrong?
most likely no. Since you are probably running a higher spring rate, along with a lower ride height, your springs are going to be substantially shorter than stock, and in some cases, wont be under load the whole time.
But all of the other corners are tight… My setup is H&R race springs with Tokico adjustables
you couldve missed something on the install, but yeah…it should be ok…
Re: lowering springs…
I have coilovers and the driver side front seems to have the most play (spring moving around) compared to other corners. You should be ok.
