Alright, so I have a ls block with all this inside
ls crank
ls rods
gsr pistons
brand new rings
bearings
brand new type r oil pump
brand new thermostat
arp bolts
golden eagle head studs
brand new gaskets
I’m worried that its not a correct build. I bought it like this and i’ve never really messed with something like this. The guy I bought it from said it was smoking white smoke before it was pulled out. So, I needed an outside opinion on what I should do. Thanks in advance!
lol yea my bad alotta things going through this head hahaha[QUOTE=R1titan911;2203085]Water in his coolant? WE WOULD HOPE SO :giggle: Mabey he meant Coolant in your Oil or the other way round
what do you have to do to get ls rods on gsr pistons ppl say you have to shave the rods or something? i have some gsr pistons i think it would be cool to build a all motor ls with them just to do it i didnt know they could go in a ls straight up
you will need to shave apx 1mm off each side of the small end of the ls rods to fit gsr or type r pistons will give you 10:1 cr with oem headgasket ls crank and ls head
im installing gsr pistons onto my ls rods, i have to shave the rods to fit em
funny you should ask, the stock cr is 9.2:1 so its a pretty big increase, plus im runing a obx header, 2.5 catback, cai & greddy emanage, im still putting everything together now, i just started porting the head tonight and ordered all new main and rod bearings so i should have them by this weekend
sounds like a sick setup man you should make a vid when its together haha i am planning on going turbo when i get everything rounded up i have eagle rods i traded obx cams for cause they were vtec and i always heard those cams are trash i only had a pair of head rests in them lol but while im runing turbo i want to build a simple all motor setup with the gsr pistons and cams + port and polish
im painting the car camo grenn, just finished painting, swapped out the blue interior for black interior, completely rebuilding the engine, catback, header, cai, gsr pistons, ported head, 18", eibach springs, hids, emanage and tune, think thats it haha
i had the greddy turbo kit on my rsxs and the emanage took a shit so i sold the kit and bought a k24 and kpro, now i make just as much wtq with the k24 and kpro than i did with the turbo kit
