Thanks for all the feedback guys,
I did get the ARP vtec studs, I used the vtec headgasket that came with the Golden Eagle kit, the stock LS gasket will not fit over the GE dowels. I have finished the swap, drove my car for the first time today. No vtec though**
I used a JDM 91 PR3 1.6 head & intake manifold, JDM vtec solenoid, GE full kit, liquid teflon for thread seal (I hate teflon tape on oil lines) stock LS distributor after hacking a leg off, now only one bolt lines up to hold it in place. Re-using old LS timing belt & waterpump for the moment, I couldn’t get the crank nut or pully off with the tools I had.
I had a few small oil leaks, have most of them taken care of (had to RTV the sandwitch plate to the block)
----WARNING!!! ELECTRICAL!!!----
**The car wouldn’t start!!! car is a 91 LS 5spd
after trying a few different things, swaping a obd1 §§§§§ (T42), which also needed a leg grinded to fit next to the solenoid. Confirm getting spark & fuel, check base timing and the white mark is a degree off when cams are lined up (OEM pr3 cam gears). But its not enough to be a full tooth off.
-I am using a p28 ecu with a skunk2 chip(4.8k vtec) and I know its not a great tune, was only going to be temp. untill I get dyno tuning. I tested the ecu in a 93 GSR, it started the car, idled ok, drove fine, vtec was fully engaged by 5k, which is earler then his stock 1.7 crossover.
-Using a jumper harness I found off Cregslist it was used and did not come with instructions. After searching the net I was able to find a company that sold a obd0->obd1 jumper that matched the single 12 pin connector wire colors. I used 7 of the 12 wires, 4 went to oxygen sensor, 2 went to vtec pressure, 1 for solenoid, there are 5 left, 2 are used to pull codes by jumping, 2 go to a ITR manifold, and 1 for a knock sensor.
ok so even if I screwed up all the wiring, or I found the wrong instructions, these instructions & harness have 2 red power wires and 3 black ground wires, instructions don’t specify which goes where. But thats not the point. None of those sensors would prevent the car from starting or even idle or drive correct?
after 3 days of scratching my head and swapping dizzys, checking spark, ect, ect… I plugged my old stock LS ecu back into my wireing harness. car fired right up, idle is nice 750, revs up fine, needs a valve adjustment but is still quieter than I ever got my solid lifer LS, that thing alwase ticked.
ok so if the p28 is good (I will re-test), and the engine is all together fine, what is the problem? bad jumper harness? the p28 need to see a obd1 §§§§§? Was I supposed to do anything to my fuel injector resistor block? I’m using my stock LS fuel rail & injectors,
Thanks for everyting guys!! will keep updating what I figure out.
ps. I baselined my car on a dyno at school befor the swap, 3rd gear 122hp / 117ft-lb all stock exceped for a open air box and zip-tye’s. after everything is strait I will dyno again.
