I have just finished installing a B16a2 head on my 91 LS block, i have everything hooked up, from vtec wires to an oil braided line. I started it for the first time today and it overheaded within 5 minutes of the first drive and the idle wont go down past 2700. The idle screw is set almost at the lowest setting. If anyone can help. Please let me know thanks!
I also forgot to mention that oil is leaking slightly out of the front left side of the head…I have a new gasket on it, but it still leaks. Also there is a little bit of smoke comming out of the port from the vavle cover.
You did plug the oil hole in the head right?
uhhh… uh oh :shock:
yeah it had it plugged and machine shoped and preped by a shop that i trust. thanks though
