i’m looking for a low milage/new water pump/oil pump from a vtec engine that i can put on my LS block, are there any pumps to avoid? also, should i not buy a used one, or is 30k miles fine?
any additional info, like do i need to buy new gaskets, etc
Originally posted by x4evawizex
[B]i’m looking for a low milage/new water pump/oil pump from a vtec engine that i can put on my LS block, are there any pumps to avoid? also, should i not buy a used one, or is 30k miles fine?
any additional info, like do i need to buy new gaskets, etc [/B]
I would buy new ones just to be safe you don’t want to be messing around with that kinda stuff cause you may find yourself replacing it sooner than later and spending more money, just my personal opinion.
There shouldn’t be and difference between the VTEC oil pumps and the non-VTEC. The 93 LS pump has the same part number as the 95 GSR which is also the same as the 00 ITR.
