LSD for a 92 GSR
Hey everyone, I’m looking to put a quaife LSD into my gsr cable trans, I have an idea of the right item number but I was told to double check, the item number I think it is is “Acura Integra GS/ LS 90-00, Integra GS-R 92-93 QDF1U $ 892.25” but apparently there is a “10bolt cable gsr” as well that this is not capatable with, can anyone help me out? Thanks
This may or may not help since my knowledge is limited, but I believe that the B17 GS-R tranny is a cable tranny. When people hear GS-R they do not think of the blacksheep DB2 too often and the 94 and up GS-R’s use a cable tranny which has a bigger output shaft.
im guessing since his part directly says 92-93 gsr and not any gsr other that hes probably correct…also im not 100% positive but i think all 94 up gsr are hydro Not cable
plus from my last week at work of tearing apart a ls cable tranny, a b16 cable tranny, and a b17 cable tranny the LS tranny LSD will fit the 92-93 gsr cable tranny as the output shaft size is the same size as the ls cable trans and the b16 is the only one that was different
[QUOTE=bryan24207;2286808]im guessing since his part directly says 92-93 gsr and not any gsr other that hes probably correct…also im not 100% positive but i think all 94 up gsr are hydro Not cable
plus from my last week at work of tearing apart a ls cable tranny, a b16 cable tranny, and a b17 cable tranny the LS tranny LSD will fit the 92-93 gsr cable tranny as the output shaft size is the same size as the ls cable trans and the b16 is the only one that was different[/QUOTE]
I’ve been talking to some people and they are saying Mfactory LSD’s and Quaife’s are pretty much identical, and Mfactory is $200 cheaper. I think I am going to run that.
