lsjdmtegs 91db1 build
what kind of exhaust are you going with?
i’m not that “loud” of a person, so i wouldnt do that vc, it’s definitely dope…is that paint or wrap?
even though the SIs are common, gives your db a better look imo.
[QUOTE=integra_hot;2295716]what kind of exhaust are you going with?
even though the SIs are common, gives your db a better look imo.[/QUOTE]
Its paint i like that its different.
The sis are temporary not a fan of them.
Im going with hytech headers
Flowmaster cat
Rsr exmag catback the straight back style
I like being different n not hsving what someone next to me would have.
Im getting the 43 code again n its pissing me off after exhaust is swapped ill tackle that again its been pouring here for like 5 days straight
Snapped these really quick in the driveway
Car is lookin good man. You’ve definitely been putting some work into her. I dig that VC, it’s different in a good way.
Thanks im noy goin to get it im thinking blue or red or black cover idk yet
what’s code 43? i dont even remember
02 sensor
Vaccum Hose leak
Fule rail or injectors or fuel filter
New o2 sensor week old.
Goin to swap the exhaust then try and figure out the problem
Used skunk 2 camber kit needs ball joints but got em cheap
Have to clean em up
Random pic
Just a heads up… Skunk2 sell Pro-Series balljoints on their site for like $30ea.
Yeah i know that y i hotvem cuz i can order new ones. Butvthanks
So i got annoyed.with the broken exhaust. So i ripped the broken exhaust off.
So im finaly inatalling.my hytec headers and rsr exhaust and magna flow cat
Removed the stock headers
The hytecs were rubbing on the ac compressor soni.grinded off one of the bolt tabs
After some manhandling got the headers on
Removed the bolts so i could mount the rsr bracket
My magna flow cat
Had to rig up a flange to match the headers
Now just have to get the flanges welded on to the cat and exhaust will be done
sweet cant wait to see the finished project bro
Exhaust is on and welded also replaced my halfshaft seal it was pissing fluid out. I.kinda destroyed the old one on instalation.
Ordered a new one they sent me a halfshaft seal not the actual transmission seal. Luckily i was at my boys shop n he had a 09 civic si tranny seal it fit perfect and no more leak wil post pictures in a few there uploading. Also have to remove the headers again so i can install my new exhaust manifold gasket and oil pan gasket all oem gaskets from acura
New oem oil pan gasket Half shaft seal (they gave me.the wrong one) and exhaust manifold gasket
This is how jacked the old seal was the spring wasnt even attatched
My boy removing the old gasket
Old seal is out
Didnt get a pic of the new seal was on the phone with acura dealership rippin them about the wrong part
My baby sky high lol
The exhaust
they put ur catalytic converter on upside down…the heat shield is supposed to go towards the floor
How come you didn’t go over the axle with that? How are you going to go over pebbles? The clearance looks low. The exhaust looks f’ing awesome I’m just worried for you, as it might get torn up… :frowning: still though I like it.
Its not upside down the flowmaster emblem is on the bottom plus i have the original heatshield just have to put it back on.
This is the rsr exhaust thats how its designed straight back for maximum flow. It does hang low but im not slammed and cant be cuz of the headers and shitty ass connecticut roads
And the heat shields on both sides of the cat just one side is shinier bottom side
