lsjdmtegs 91db1 build
Stole the sway bar from the parts car since mine was bent
Poly sway bar bushings
Cleaned up the bar and getting.it prepped for.paint
My son picked the blue so I had to do it
Also did the clutch cable bracket
Before
Grainded the rust off and prime red it
Conversions almost done. Things left to do
Put in half shaft and axles and bolt up the suspension
go through engine bay and tighten up all bolts
Swap driver side mount to innovative mount
Bolt up shift linkage to transmission
Drill holes for shift linkage to mount
Remove dash and install manual pedals
Plug in my old conversion harness plug that is already wired to trick the ecu
Install manual ecu
Install gsr cluster
Drill clutch cable hole and install clutch cable.
Started ripping the dash apart
Started to drill the clutch cable hole
U can see the pilot hole
Auto pedals and manual side by side
Manual pedals are in
Gsr cluster in
Also picked up my new parts from acura
Shift linkage bolts n washers and starter bolts
Also installed front sway bar and new sway bar bushings and endlinks
Also got some transmission fluid
That blue very closely resembles Cusco blue… looks good man.
Nice updates!
Thanks everything is in but now when I turn the key nothing happens and my oil and battery light stay on it doesn’t even try to crank
clutch safety switch override?
looks good jeff
When I used my old plug that was already (sliced and wired) it wouldn’t start
So I stripped the tape off and the black wires weren’t spliced. When I did my old conversion I forgot my boy spliced the wires before the plug harness side. So I spliced them and she started right up
I was doin everything solo so I was dirty and forgot to take a lot of pics sorry :frowning:
So this car loves me so much tie rod came off the joint thank god it was goin in to my driveway.
So i changed the whole steering rack while i was at it since mine was leaking.
Also changed the shifter to some no name short shifter so much better but have to loosen it a lil bit its so tight can barely get into 5th
New steering rack from.donor car
Installed my innovative rear mount
Put a no name short shifter on while i was at it
Had the cut the old bolts out and put new bolts
Took her to work and she was covered in pollen and dust
So i washed her up
So my seatbelts were stuck forward no beeps nothing
Went to the car wash yesterday some how blew a fuse and my car woildnt start
So i found 2 blown under hood fuses once i replaced the back up fuse my belts started working again so im happy again
Snapped a few pics at the cars wash again hate pollen and i actualy finally vaccumed it
And interior first vaccum since i baught the car
man i want those seats…shit they so minty!!!
