LSVTEC, knock sensor, and a CEL...
Now I don’t have the knock sensor hooked up on the block and I’m getting a CEL for it. Is there anyway to disable the knock sensor without rechipping the ECU? BTW, I’m running a P61 92-93 GSR ECU. TIA for the info.
hehehe, you could just use a short wire with the knock sensor attached and pin it to your ECU. That would get rid of the CEL. hehehehe. It’s not going to cause you any problems. The knock sensor is only a “indicator” sensor. It’s not like the J&S. It’s doesn’t retard timing or anything. But that orange light is pretty annoying. hehehe.
Tried that already Dan. It’s mounted up under my dash on that metal support that’s supposed to be a good ground (tested it with a test light) but still no luck. Any other suggestions?
where did u get a 92-93 gsr ecu??? i need one
Bought one used off thepartstrader.com.
Well the knock will be disabled when I get the Hondata hooked up next week.
