Ok, so I’m building an lsvtec engine for my '93 LS. B18b bottom end, B16 head, 2nd Gen B16 Intake Manifold… But here’s my dilemma. The factory B18A setup in the '93 has the Fuel Pressure Purge Valve/EVAP Purge Valve and MAP sensor all tied into eachother, then going to the Throttle Body. How does everyone out there run a Gen2 B16 manifold with a MAP sensor on the throttle body, and by-pass all the vacuum lines in the purge-system? I was possibly thinking of keeping the fire-wall mounted MAP sensor, and using the factory '93 throttle body…
Im probably making it harder than it needs to be, but I just want to make sure i don’t come across any idle problems due to the vacuum system.
