will tuner/racing style lug nuts work on stocks rims?
will the taper nut still work on our stock ball type seat?
they will work but it is not something you want to do because of the differance in shape. kinda like using a square condom. :stare:
I wouldnt use tuner lugs on stock wheels and I wouldnt use stock lugs on aftermarket wheels.
Anybody know thats the torque spec on a tuner lug nuts? getting some today just wondering
stock torque if theyre aluminum and mybe 10lbs more if steel. I think it should really stay at stock torque since the stock studs wont take anything out of normal.
Ive snapped studs and end up needing to replace them with extended arp studs.
80 lbs
