manual rack&pinion conversion??
i have a 93 ls special and it has a power rack in it. I took all of the power steering componets out of the vehicle so all i have left of it is the rack and pinion i would like to convert it to a manual rack but didnt know what racks will work on a da k-frame??? will a 88-91 crx rack bolt on to a da k-frame i have one of these on hand,but not sure that it will work and i didnt want to tear it all apart without being 100% positive that they are compatibile? and then be stuck without a daily driver:rant: if you know anything on this subject please how a guy out and share your knowledge?
search on here…
it will fit but you are suggested to buy the gear from an aftermarket company in order to have the same turn radius as the integra.
why not just use the crx 1?
Because it’s designed for a shorter wheel base?
would that make my turning radius tighter or wider?? tighter would be better
wider… which means your turning would be slighty off .
Qualfy makes the steering gear for the rack. It makes the turn radius match that of the stock integra PS rack…with out the need for the whole PS set up.
theres a thread that should be on here still explaining in great detail why its better for the swap. Apologys if im off with my answers its been a long hot day in so cal…=(
HERES THE THREAD EXPLAING THE HOW TO AND WHAT NOT.*
http://www.g2ic.com/forums/showthread.php?t=88673&highlight=Manual+rack+crx
