so i been wanting and seached for the manual seatbelt conversion and all the threads and no one has talk about the electrical wiring. so im wondering if you get the canadian seatbelt or jdm, is there a harness behind the panel already to just plug and play?? or do you somehow extend the the harness in the front or spice it??? please if anyone knows anything about the electrical process of the manual seatbelt conversion, please get back at me a.s.a.p because the auto seatbelt sucks a$$:(
manual = you do all the work yourself putting them on/off
auto = relax, and it will do it itself
so if u want to switch to manual there is nothing electrical about it, just like every typical manual seatbelt cars
Harness? You can remove the auto seatbelt controller located on the passenger side behind the paneling in front of the door. There is a switch on the drivers seatbelt, but no need to even attach it. There is nothing you need to wire up.
hrmmm…just making sure before i do the conversion seatbelt for safety…i was wondering if you answear this question…why come manual seatbelt only stops you when the car breaks?? like its wired up to the breaks? and if you take the oem seat belt motor apart from the seat there are wires that are connected to certain location…theres a wire under the seat which indicated the seatbelt warning and one that is connected to the clip that connects the seatbelt…and IF ITS NOT WIRED UP, THAT MEANS YOU CAN USE ANY SEATBELT WHICH SHOULD WORK FINE
the seatbelt stops when u brake or pull quick on it cuz they have an internal cam mechanism they arent electrical at all…only the buckle part has a wire that tells the the dash light to go on if u unbuckle the belt while the car is on
