Is it possible to remove the filler bolt and refill the transaxle with MTF from the top of the engine? Or is that impossible to do. that you only need to refill it under the car?
I remember someone telling me that you can remove the speedo cable from the top, just dont lose the clips. Then use a long funnel.
But you may need to remove the filler bolt anyhow, unless you feel confident in guesstimating how much you poured in. The oil amount needed is 2.3 quarts.
It is. But it would be really slow.
If you open your hood and look around your transmission, you should see a black rubber nipple you can pull off. Under that is a small hole leading to the transmission. You might be able to get some pretty small tubing in there. MTF is fairly thick, so this will take awhile.
Or it’s just a good way to top off your fluid if your anal or something.
