Hey peeps. My integra has a few probs in the driver side door. when i roll up my window and shut the door the window will roll down on its own a few inches depending on how hard you shut the door and the window will rattle inside the door.
Plus when your sitting inside the car you cant open the door from inside you have to roll down the window and pull the handle from the outside (talk about ghetto). I took off the door panel today and looked at it for awhile and i cant tell whats wrong. I have roll up windows and manual locks. Any help will be appreciated thanks!
Any ideas?? i figured out the problem with the door not opening from the inside. The wire from the inside isnt pulling all the way so the door wont pop open. The metal brace behind the handle for the door to open is missing a screw and needs to be bolted back on to the door so it will create more leverage. but im still puzzled about why the window rolls down on its own. but if this helps (hard to explain) but when i roll the window up to the top the knob will still allow you to keep rotating but will pop the window up to the top than come down an inch after the pop.
But any ideas why the window is doing this???
