Manual Windows
Can anyone help me out? I took off my door panels the other day and now my window opener’s don’t match up (not in the same position) as the other side so it kinda looks wierd. Can anyone tell me how you take those off and re-anign them again?
y2ken@shaw.ca
Yup, sure can…if you position the handle up then pull it away from teh door and look down in it, you will see a little metal thingamajig, you need to get a screwdriver or two and try to pop that thing out…just keep trying to move it down. THen when you get the handle off just put it on aligned with the other side and slip the metal thingamajig back on and your done…it is really quite simple. IM me if you need help musicisair
Thanks alot dude…I’m going to give it a try right now!
