Hey i just had the passenger window motor go out today, and i don’t have money to replace right away, so is there a way to manually crank a power window? need help fast, Only car, and its been raining , and the window is stuck down!
Do your window wipers work? Cause the relay fuse for the windows is the same. Maybe, perhaps not. Anyways, don’t lock yourself out. Try the electrical section.
are you sure its the motor thats bad? troubleshoot with an electrical diagram to be sure. you may be able to power the window up simply by applying power/ground to a terminal. good luck tho
