Had some damage to my drivers door. Instead of repairing the door I found a door at pullapart same color. But it was a crank window and mine is power. I have gutted my door and have the new door ready except for the manuel window crank. Whats the trick to removing the clip on back on the crank ??
And yes I have search and found post that talk about removing the crank and that there is a clip. But no details on how to remove it. I know there is a simple trick and I must be having a brain-fart. But I can’t figure it out.
The open pqrt of the clip faces away from the handle, or is supposed to. If you dont have the little tool, just use a screwdriver and pry one side of the clip open. That should let you get the clip off.
It looks like this:
So the round part should be under the long handle part.
Oops after reading my post it is confusing. I have everything of the door except the crank gear that mounts to the window track. It need to get the manual crack gear out so I can put the motor in it’s place.
I figured it out. You have to swap the regulators. I have a manuel regulator if anyone whats it. Now on with the engine swap.
