when i disconnect my vtec controller my ecu throws a mapsensor code but my vacumm lines are hooked up properly… what causes the ecu to throw a mapsensor code and what does it mean??
When you installed the VAFC you spliced in the MAP signal wire (among others). If you disconnect the VAFC w/o touching anything else you have a break in that signal.
