well i am finishing making my car legal for the bar i have my throttle body with the map on it and my question is can i just plug my plug into it and it will work or are the wires in a different order on them i cant seem to get it to work. so any help would be great
thanks
justin
The wires for the firewall-mounted MAP are in the same order as the ThrottleBody-mounted MAP, you should just have to extend the wires to reach the throttlebody.
If you extended the wires, you may have gotten them crossed by accident… or a faulty MAP… or a blockage in the throttlebody.
Is the ecu throwing a MAP code, or is the motor just running badly?
