Master Brake Cylinder
: Are the master brake cylinder with ABS all identical from the years 90-93, or do they vary from 90-91 and 92-93? so basically i want to know if they are interchangeable or not?thanks
ABS ones are interchangeable with ABS ones and non-ABS ones are interchangeable with non-ABS ones.
They ABS and non-ABS ones are internally different, but I dont know if you can swap between then. I know that they will bolt up, but I dont know how they would actually work.
Later,
BR
The brake m.cyl are exactly the same internally. The ABS ones brake line fitting (only one) is larger than that of the non-ABS ones.
Joe
