Master Cylinder Making Noise
Wsup G2IC,
Im doing a full rear brake job on my 92 integra. I resurfaced my brakes, slapped on new Nissin Pads, and installed goodridge stainless steel brake lines. I took everything apart and let it sit for a day and half. what i mean by taking everything apart is that rotors are out being resurfaced, brake pads are out, and i replaced the old brake lines with the new brake lines, BUT i did not screw the stainless steel brake lines all the way. Coming back to work on the car, i realzed the that it was leaking a little bit. after putting everything back together, i only bleed the rear brakes only because i only did a rear brake job. After bleeding, my master cylinder or brake booster is making a noise. Could it be air in the system because i did not do a full bleed? or could it be the brake booster is done?
The noise is not making a “leaking sound” its more like metal to metal but a deep tone sound.
please give me some info.
