Maybe you guys can help
So i was low pressure washing my engine bay and there is a ground running from the top of my block to the sub chassis deal by the front clip (if thats what it is called) and i have a battery relocation mod so the black cable is grounded to the start with exposed wires…could this have something to do with my odometer melting, speedometer needle falling off and the car not starting, what is weird is it started right after i washed it and i drove it around for a bit then after that it did not start
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
