Milage wire
My friend has a 92 RS. and his Speedometer does not work, and i wanted to know how do you go about locating which wire is for the speedometer.
It sticks out of the top of the tranny twords the back. It points straight up. you can follow it from the fire wall. It is the cable that comes out at an angle twords the passangers side and plugs into th etranny. The cable probibly rusted and snapped. they are about $ 30.00 from Acura. The best way to install it is to plug it into the cluster feed it through the fire wall as you install the cluster. Then plug it into the tranny and install the lock pin/clip.
Thanks for your help man,
That explains it.
Thanks again.
