my mirrors stopped working today. i have no power to the switch but i dont find a fuse specifically for them. what can the problem be? thanx
If all the fuses are good, check the door harness connection to the dash harness in the door jamb, also make sure you do not have broken leads in the door to chassis harness boot. 94
what fuse would i check?
anybody???
Check them all. 94
sorry fcm but i dont have a diagram for my fusebox and i dont wanna pull out every fuse individually. what fuses are related to the mirrors?
Sorry, don’t know which one it is.
You do not need to pull the fuse to test it, just touch the probe to both “test tips” of the fuse, both will show 12V+ if the fuse is good. 94
alright well i know my rear defroster button stopped working too so maybe this is run together. ill just pull all fuses and check them as i pull em
