Mismatched Manual/ Power windows
So basically I bought the car thinking that the passenger’s side door was missing just the window crank, so I went to the junkyard and picked up a crank but when I got home, I noticed there was nothing on the door panel for the crank to attach to. I took the door panel off and noticed that this door came off a different car that came with power windows. I’m pretty new to the integ world so I apologize if my question is novice. I was wondering if I would be able to convert from the power windows to manual windows. If so please give me small instruction on how to do so. Please and thank you!
easiest way to do it… find an RS door and swap it out with someone that wants power windows n stuff. literally replace the whole door and wiring to make it easier. finding the same color would be a big help. but that is the easiest way.
re:
Thanks alot man. That’s what i was thinking too since it’s kinda hard to fit the regulator inside the door and work around with it at the same time. I’ll try finding someone ASAP.
I had power window’d doors that both broke - and it was getting to be a pain trying to fix them, so I just got new doors from the junkyard for 50 bucks a pair. Worked great, it’s 4 bolts per door plus a pin… Your speaker wiring changes, however - the plug for the power has more wires, obviously, so you should keep that in mind.
Though it’s a very simple swap…
