Anyone find a cure yet? Happened to me today… ![]()
I have two different sized toilets in my house. I find mlgnott far less often when I use the taller of the two.
Because pressure is distributed more evenly by the taller one and no pressure points pinch off blood flow.
sadly no… there may never be a cure.
i get it bad… but only the left leg, weird.
i just encountered some left leg “NOTT” as well. was there for nearly an hour. That was an endurance dump…
the only time I ever had this occur was on the toilet in the half bath in my parents basement. It had one of those vinyl covered foam toilet seats from late 70’s early 80s. Maybe there was too much give?
Well, if you stay planted with heels up and pressure on your toes, it does help eliminate “NOTT” but for only a short while. I’ll be conducting more research shortly.
How about a memory foam padded seat?
I only get it when I get carried away reading a magazine or something, then, depending on the seat, can be quite severe.
Hey Josh.
