I know that it can be done, I just don’t know how… has anyone set up the 2 aux. horn buttons on the momo wheel to make the cc work?
so… I guess no one has done it?
while shoping for a MOMO steering recently, I noticed that MOMO offers an optional button that you can buy to attach anything to it. I gues you could fit two, one on each side or maybe modify it to take two bottons on one side. I"m sure it comes with the proper wiring too so it passes through the hub.
BTW, I assume you have a momo on your car, what is the hub adapter no. you have used? Any different from ones without CC (like mine?)
the momo pilota has three buttons (one in the middle and 2 where your thumbs would go, which come wired for the horn.) but I know that somehow you can wire the 2 extra horn buttons for cc.
how about if you keep the one in the middle wired to the horn and rewire the two buttons for CC?? All you have to do is extend the CC wires to those buttons you know…
well, the new momo hub doesn’t look like it comes “rtr” for cc. I’m just not sure which “groove” in the hub is for cc.
BigE, I remember clearly being asked if my car has CC or not when i shopping for a momo steering. The hub is about 40$ or little more, you can have it changed. If you have a voltmeter, remove the hub and check each connector on one side to where it leads on the other side using the connectivity alarm (or ohmeter).
Good luck.
