For all you custom exhaust ppl . . . USE IT!
I’ve had a hell of a time trying to get my exhaust to NOT sound like a busted azz 2g eclipse. Here was the progression . . .
Ricer Days:
Hayame Fart Can on Stock piping. MEH! lame.
Cheapo Days:
$50 used OBX 4-1 Header which turned out to be a badazz little piece.
Learning More:
2.5" custom exhaust with stock cat and resonator (2.25 ends cut off b/c i was too poor to buy a real one) to a Comptech 2.5" muffler. Meh! Slightly less lame but getting there. Later added a TSX exhaust tip (irrelevant to our conversation.)
Amateur Racing to Current:
Switched to a high flow cat, JDM ITR Header, and added a Vibrant resonator to the system. Not lame until 4k when it STILL sounds like a complete piece of shizzleit.
- before you flame keep in mind I have in my genius NOT taken the time to bother to ever have looked down teh pipe of a stock resonator. i’m kickign myself for it b/c had i bothered to look I wouldn’t have been in this predicament to begin with. I felt it should stay b/c I’m looking for a quieter sound as I’m doing a lot of driving with it these days. *
TWO DAYS AGO:
Finally decide to pick up the Moroso Spiral Flow Long tube resonator on the suggestion of a friend. Dropping the car off I went to run an errand. My friend took it upon himself to decide that the stock resonator is going in the trash regardless of my returning to protest. Upon returning we look down the stock resonator to discover the piping leading into the baffling doesn’t stop at the baffling like a true straight through design. It continues about an inch into the center of the perforations. Now this is a problem b/c as the increased amount of exhaust gases travel through the resonator they slam into the pocket created by this protrusion. Then they travel backwards and slam into the other side. The “resonating effect” is great for sound deadening and the “economy” of the stock exhaust. However for performance and current setup sound it was HORRIBLE.
The Spiral flow looks like a normal resonator (round). Inside looks like a spiral water slide twisted around a hollow tube. So the exhaust has 2 ways to travel. Straight through, and along the “waterslide”.
This thing is amazing. It’s mostly used on trucks to even out tones, and that is preciesely what it did here.
The exhaust sounds MUCH better than my friends Greddy SP2s, Apexis, And even the RSR. It’s SMOOTH at every point up to 7500rpms where it gets a HAIR raspy.
Butt dynos lie, we all know this, but the overall feel of the car is COMPLETELY different. 4 people drove it after we installed the resonator and immediately noticed the smoothness of the drive.
We will dyno the car here shortly this being the only change since the last run, and we’ll see what the stock resonator was hiding. For now purely from a sound standpoint, this is THE resonator to use for custom exhausts.
My head tech at TDC Motorsports exclaimed “Well, I guess what I’m going to be doing for my new hatch”.
Thanks.
Manny
