motor holding back...
ok well i have a 92 gs-r and well it feels real sluggish. like when stopped and i start off and get on it, it feels like its being held back. the other night i started off and got on it shifted to 2nd and cherped the wheels…thats the first time thats ever happen in the 3 months of owning it, so i know its being sluggish. it seems like its off and on sometimes. like i get in it start it up and go runs good… then turn it off get back in start it up and it wants to act up. but when in high rpms it seems to be fine i believe. it has 114,000 miles on it and when i bought it i changed out the distributor because it was screwed up. but thats it anyone have this problem? or have any thought in mind what it could be?
Check ur Timing on ur distributor? Advance it back to 16 degrees or go up to 18 degrees if u feel slugish i guess…Also if u havent change the spark plugs and wire check them to see if they are in spec with a voltmeter and using an online help reference… Good Luck.
thanks alot ill try those options.
does anyone know the spark plug part number for ngk?
Look it up. http://www.ngk.com/
i was just doing that…which one? im thinking the v-power or the oe laser? any input its a stock b17a about to have a couple bolt ons.
http://www.ngksparkplugs.com/part_finder/car_truck_suv/results.asp
I run NGK V-powers and have never had a problem, they are the OEM plugs.
really why does it say the ones above them are oem? but im leaning toward the v power. so those are the ones you can get at honda right?
Because the stock ones for a vtec motor are platinum plugs and copper for non-vtec.
And you can buy the NGK plugs at any auto parts store.
well im asking about honda because i work there…so ill just check it out. so get the v power. and stock wires are 7mm right?
Yea what they say above or if u have the original hood and it came with the spec labeled you can refer to that too for spark plug type. As far as wires goes you can get ngk or any other ones that are standard to oem replacement when u ask the store. Either way it will be worth it and probably better then what u have in right now if it havent been change in time good luck.
