What are the differences btwn a 92-93 RS/LS/GS and the 90-91 (All 5spd Models) / 92-93 GS-R??
When ordering after market motor mounts, this how they are categorized…What determines this difference? I would like to order the Billet Innovative Mounts for my 92 RS…but they tell me they are only available in black for my yr and model.
well 90-91 are all the same no difference in the model of the car but the 92-93 gsr use the same mmounts as the 90-91 and all of the 92-93rs/ls/gs are the same, i guess they just changed they way the mounts are bolted to the chassis compared to the 90-91. i guess they dont make the billet mounts 92-93 which is weird imo i just purchased some innovative’s for mine but mine is a '91
oh yeah also you would use the same mounts unless your going k-series,h-series and if your using a hydro tranny then you would need the actuator.
that didn’t answer anything…:roll: You basically just repeated what I said…the question is: What are the differences? What is different in the 92-93 GS-R from the 92-93 RS/LS/GS??
i don’t mean to jump in your thread & ask a question but i have a similar question. so when buying mounts, do you buy it for the year of the motor or the year of your car?
i know people that have but it moves around alot an you cant really get on it so i would not unless it was super temp an i was not going to drive it really
from my experience… the 90-91 driver side mount is thinner from the 92-93. now if you have a db2 (92-93 gsr)chasis like i do the driver side mount is thinner like the 90-91. i went through this when i was putting a temporary b18a1 in my gsr chasis
Well, I have Innovative mounts on my 92-93 GS DA and My motor has a tilt…Driverside is lower and my rear bushing is popping out to the tranny side and Its a freakn head ache. My Opinion is buy Hasports dont wast ur money on BS!
the only difference that i noticed is that the 90-91 driver side mounts is a lot smaller than the 92-93 mounts. the tranny (i dont know cuz i used the inovative auto to manual trans mount), front and rear are interchangable. i know this because i just recently did a b17 swap into my 92 auto. the b17 that i bought, the driver side mount was identical to the 90-91 , but i’m not sure if that b17 was previuoly swap into 90-91? correct me if im wrong.
Let me make this easier for every one. All 90-93 5 Speed DA’s use the same mount except for the driver side mount. The 90-91 driver side mount is diffrent from the 92-92 and yes that includes the DB2.
There isn’t any more angle on the 92-93 mount, because the block mount is the same. The difference comes in width between the years, where the 92-93 is wider than the 90-91s
You aren’t exactly too clear in your wording there, might want to clarify a little better for others. The DB2 uses the same driver’s side as the 90-91s and the 92-93 RS/LS/GS is the wider piece (look at the part numbers I posted above)
