Motor mount Differances 90-91 vs 92-93
I know the 92-93 is wider
But has anyone used a 90-91 mount in 92-93 car?
technically it should fit and is the same since 92-93 gsr uses the 90-91 mount. Just making sure
thanks
gsr use the 90/91 mount the part on the body is skinner on the gsr like the 90/91 even tho it a 92/93. An the 92/93 ls,gs rs is wider so you need that mount hope this helps you
