Ok so im new to g2ic but anyways i have a 92 integra gs and my ls motor is going on 217k and i was thinking of doing a motor swap before too much longer! any suggestions on what motor i should get and which trannys will bolt up to which motor ? any advice helps thank you
this question has been answered many time recently, and there are like 2 or 3 recent threads asking the same. you should just take a look at those also if you’re just going to dd and not really plan anything special just replace it with another b18a or b
would the b18b bolt up to a ys1 tranny? and sorry about that thats common sense shoulda searched before posting . also i was wanting to build the new motor . ive heard the b18’s non vtecs have quit alot of torque when built properly .
all b series 5speed trans (excluding prelude b series) hook up the each other, hydro transmissions, need a full hydro conversion or the lever/hydro kit in order to work properly(maybe a mount too, don’t remember though). It really depends on what you want to do. all b16 cable trans are a direct bolt on to a 5 speed, the 92-93 gsr cable trans is also a direct bolt on, but you need a hydro trans clutch (94+ integra) in order for it to work properly.
If you plan on daily driving the car, either rebuild the tired b18a or get a b18b, slap it in and call it a day. Either way they will both feel way more powerful than the tired motor you have now. since your obd1 you have the option to tune and do a bunch of other stuff too, do some more research and think about what you want to do with the car before you tear into it.
[QUOTE=mildsquare;2113809]the 92-93 gsr cable trans is also a direct bolt on, but you need a hydro trans clutch (94+ integra) in order for it to work properly.
This is an incorrect statement.
If you’re using a 92-93 cable b series transmission in a G2 you will want to order a 92-93 Integra clutch kit. If you order a 94+ clutch kit the pressure plate, disk and flywhee bearing will work just fine (exact same parts) but you will end up with the wrong release (aka Throwout) bearing. Throwout bearings are different for the cable and hydro transmissions.
This stuff has been gone over repeatedly over the years, there’s no reason for incorrect information to be thrown around anymore. :search: :search: :search:
i greatly apprieciate your guys input. it has a exedy replacment clutch in it right now. ill probably get a b18b then. i found one on the internet already compression tested and garenteed low milage for 650. thanks again guys .
As previously stated in this thread, and stated many many times in the past (:search:) any b series transmission will bolt to any b series engine (excluding the not very common and typically overlooked prelude b series from the late 80’s / early 90’s).
this might be a stupid question but i have an extra 89 zc motor n tranny lying around. i could use that tranny right? i think its answered but i want to make sure.
