mugen 26mm rear sway bar??
since it basically fits like the stock ITR one, wondering if anyone can imagine any problems with this one on a DA?
I think that would be a really big bar to put on our cars. Unless you are using this car for track duty then I think it might be a little to much for your car without some major strengthening of your subframe.
most definitely not just for street driving. but seeing as how the mugen bar bolts up to stock ITRs, in the same way that the 23mm jdm bar does.
it should bolt right in correct?
Well the ITR rear sway bar it’s not a bolt on thing per say. You’ll have to make up your own sub frame reinforcement as I did since no one makes on for Da’s.
ITR bar on our DAs is not justn a bolt up:
http://www.g2ic.com/forums/showthread.php?t=124417
http://www.g2ic.com/forums/showthread.php?t=183413
i would look for some proper subframe reinforcement if going for a big 26mm bar… hth
