Hey all, just wanted to bounce some stuff of you guys as I’ve been having a lot of issues.
A week or so ago I installed an Injen RD1400 Cold Air Intake. I removed the stock intake system and installed everything to the t according to the manual and everything seemed to sync up. After going for a test drive, I noticed I would bog down when trying to accelerate, I.E. it was underpowered. I think after a while it went away, and I drove it pretty hard as I enjoyed he sound and it seemed like things evened out.
However, I noticed there was a slight “whistle” whenever I would accelerate. At first I thought it was downshifting, but then came to realize it really whined whenever I accelerated. Studying further, it would stop whistling or whining after I would get enough revs.
Recently, I’ve been dealing with major suspension issues so I focused on that and let it go a bit. Then, it seemed to get worse; to the point where it was difficult to drive in elevated areas, and then after replacing some UCA’s, it even Idled rough and a little sporadic.
The next day, today, I started her for a little and drove to a spot to check the tightness of all the fittings and go through the vaccum lines (guessing and going by the hood diagram). I found the rubber coupling from the cone filter onto the CAI pipe had a loose band, so I tightened it.
I also noticed that the fine edge of the hole (where the CAI goes down into and where the old box use to drop through), had eaten a little into the pipe. I could feel the cut, but I don’t think it broke through, and I put some material between it and the pipe until I can find a 100% solution. I didn’t look exactly at it, but It might be the air leaking through a possible hole where I’m getting my “whistle” sound.
It’s hard to hear, but you can tell if you listen closely when I accelerate the “whine/ whistle”. Sort of a “heee(warble)”
As I was looking for vacuum leaks, I listened to everything for hisses and what not. After the engine ran for awhile I heard a pretty abysmal sound that I thought was coming from the intake manifold, but I’m not sure. It definitely was internal to the engine or IM.
Here is a video of it:
I’m not sure if it’s associated with, or a completely different beast, but I was an idiot a little back and topped off the oil too much. Not sure if it can be associated with that, but the bogging down started immediately after CAI installation.
(the pic is after a clean wipe after the engine warmed up)
I did a bunch of research and ( as it’s usually hard to find Gen 2 articles) I came across a couple general postings about how B18’s will not like you throwing an aftermarket intake on, and the MAP sensor can go bad.
I’m really just wondering, mainly from the video, how bad it is for me to be driving around. my gut says don’t even drive it to a shop, yet it’s my DD and I really can’t just stop driving it. Hoping maybe I did something stupid and forgot to hook something up properly.
Appreciate any help!
Ian
