Not even a bit. Little green lights on the dash do not even light up. Hazards are out too. Fuse is good, is there a relay under the hood for these? Sucks Sucks Sucks. ![]()
try replacing the flasher. It is the big silver thing in the fuse panel under the dash.
you might be out of blinker fluid. i’ve got some extra sitting around… $20 for 5 gallons. that’ll give you plenty for a few years!e-mail me if you want some. buyer pays shipping though. ![]()
do your map lights work? does your clock reset everytime you turn off the car for a while?
could be one of the relay fuses. check the one on the left side in the 2nd row down from the top of the driver’s side kick panel. (i think that’s the one).
use a voltometer to make sure, cause sometimes you can’t tell they’re blown/partially blown
Har Har Har…
Originally posted by integdrag
you might be out of blinker fluid. i’ve got some extra sitting around… $20 for 5 gallons. that’ll give you plenty for a few years!e-mail me if you want some. buyer pays shipping though.![]()
I need some brake light fluid also if you have any laying around. ![]()
Yes, the map lights work, and nothing resets when I turn the car off. How do I check these relay’s? Or should I just start replacing them?
Anyone know if they are expensive?
hmm… brake light fluid? i got a friend in japan… let me call him and get you some JDM Honda brake light fluid. may be expensive… like $15 for a 12 ounce bottle. is that alright? anyone else need some… maybe we could get together a group buy?
just having some fun with you man… trying to cheer you up with your electrical system snafoo…
josh.
And now…
Wipers do not work either. Wont move at all. so now, blinkers and hazards and wipers quit.
Integra 3
Kirk 0
:mad:
i would go and check ALL the fuses regardless of what they are for. Next, if you had any electrical work done recently(like rewiring this, or adding this) double check all that. Then check all the bulbs and wires for the turn signal. The turn signal wire could have been pinched causing a short. If you replaced your tail lights, check to see if any wires could have been pinched there. If all that doesn’t solve it, check the relays for each part(turn, wiper).
Check to make sure the connector is connected to the hazard switch, cause if the hazard(4-way) switch is disconnected, your signals or 4-ways won’t work. You may just need a new switch.
HTH
