my car is cutting like around 5000 rpm
todday i was driving my car an i step on it an for some reason it red line at 5… an it cut… like it die and i try to give it gas but it turn off…
i think it migh be the fuel punp or the filter…
Cel?
u mean my #…
no I ment Check engine light, as in is there one?
what happens when you try to start it? it can be MANY things if you don’t give more info it’s hard to help you out.
it runs great but if i step on it i dies … an when i try to start it i have to wait a couple of min to star but it starts fine… chek engine light turns on an off when it feels like … lol
Check your alternator
nah the alternator is brand new with battery… it use to do some thing like that but i change the alternator an batery an it work good…
check what codes you have and start with that.
LOL… =) so when the car died on you is their any power in the car does the radio windows work? does the engine even crank?..
the car runs perfect but ones in a while i step on it an it turns off… then i have to wait a litle so i could turn it on again…
Look for the “skipping tach” writeup in the archived teg tips.
One/more of the wires inside your distributor doesn’t have a good enough connection.
but if the wires were not connect it righ the car would be miss firing righ?.. what do u mean “”“Look for the “skipping tach” writeup in the archived teg tips.”“”“”
Thats sounds like a dirty fuel filter. Its the cheapest and easy to repair.
just fix it today an it was the distributator so is running like a chanp…
every1 seems to be having distributor problems lately i jus changed mine…mmy car would start n drive for a lil then cut out…crank but not start…changed the distributor and its running nice
yeah bro i thou the dist when bad an dats it… not like that though
every1 seems to be having distributor problems lately i jus changed mine....mmy car would start n drive for a lil then cut out........crank but not start..changed the distributor and its running nice
