Ok i crunk my car up but after like five seconds it just shut off. I kept trying to restart it but it kept cutting back off and all the warning lights came on such as the battery, oil, engine, etc. So after about 10 tries it started and i drove it about 4 miles home. The car is a 89 Camry, Automatic if you know about cars please tell me what may be wrong… I’m thinking it was the battery but my dad says it may be somekind of clog somewhere…
there are a couple of things it could be, Frist you might want too make sure all of your injectors are sraying Right,and if that is not the problem you might be missing a spark and it causes the car too die but i dont really think that is it becuses if you are skiping a spark, i dont think the car would start at all, but if you have not tryed too get readings from the ECU then that would be a good idea…I dont know about that car but the Integras all you do to Get your reading by stick two pins in the ECU and you check engine light will flash and you count the flashes and then look in the book and see what the problem is.Your car might do the same thing,also changing the Fuel Filter there could be some junk in it causeing the car too die becuse it is not getting enought fuel too the Injectors… But Good Luck Hope that Helped
Thanks 93 I’ll try to check on some of that stuff you mentioned thanx…
Yea!No Problem…I think you dad might be right it sounds cloged to me…While you are at it you should get some new plugs and wires… :drive:
check the run wire and start wires from the ignition they may be loose or bad connection …
