Well as simple as this fix seems I’m at a loss for how to fix it.
My scenario, I advanced my timing 2 days ago and all was well…I even felt a difference in low end power (less bogging at low rpms) Well earlier today my car starts leaking oil from what looks to be the oil filter. So I assume its a blown filter gasket (I think it was on too tight, my bad) Even though I was only 500 miles into the new oil I replaced the filter for good measure and topped off my oil pan. I don’t think any of theses things are the problem, but I wanted to install a fuel pump kill switch today.
I’m working on that project and test to see if I cut the right wire (ylw/blk under rear seat). She cranked almost started then died, so I had the right wire (huzzah!), but after finishing the switch I go to crank her on and there no go. I listen for the fuel pump and I can hear it turn on when I turn the ignition key. When I turn it to start the enigne just ticks, My rpms go up to like 1 or so but there no fire in the pistons.
Did I flood her by checking for the pump too much or do i have a bad ignition coil? I dunno. I’m so upset my baby isn’t running I can’t think plus it pretty late at night. Are there any late night Gen 2 gods out there to help me?
Thanks in advance guys!
