my db2 build
i recently picked up a aztec green 92 DB2 and love the car. the car needs a little freshening up and in the proicess I am planning the fallowing
-full rebuild of b17a1
-new coil; overs
-4-2-1 2.5" header
-2.5" magnaflow exhaust
-head work(dual springs, tit valves, tit retainers )
-skunk 2 stage 1 tuner cams
-skunk 2 ultra intake m,ani
-eagle H beam rods
-11:1 cr pistons
-LSD
-grippeir tires
-hondata s300
that is the jist for now. I wantr to maske the motor stronger to preserve the b17. I will have pics up later on. input is appreciated
Nice to have another DB2 up here.
I wouldn’t waste your money on sleeves unless you’re going to go turbo.
Also, what are you planning on doing with the car? I wasn’t happy with the performance of the T1r’s when I had them.
the sleeves are a waste for your build. you would be sleeving a stock motor basically… you should refine youre list to make it more organized. it looks like youre just buying random parts with no goal in mind. big mistake…
first decide what the car is going to be used for THEN make a list based on that. also, do 1 thing at a time. if its not broke then dont fix it. if you want to rebuild the motor for whatever reason then focus 100% on that and once its done then move on to something else. dont just throw parts at the car for the sake of doing it.
[QUOTE=DA_all_day;2316882]the sleeves are a waste for your build. you would be sleeving a stock motor basically… you should refine youre list to make it more organized. it looks like youre just buying random parts with no goal in mind. big mistake…
first decide what the car is going to be used for THEN make a list based on that. also, do 1 thing at a time. if its not broke then dont fix it. if you want to rebuild the motor for whatever reason then focus 100% on that and once its done then move on to something else. dont just throw parts at the car for the sake of doing it.[/QUOTE]
probly right on the sleeves being a waste. im just now planning my build out, noting is set in stone. but my mod list is kind of a guideline for now. I know I wana do full boltons with cams, lsd, better suspension, and a full motor freshen up. also wana bump up CR. that’s where im at. honestly, the car feels fast as hell being bone stock and I love it. sooo much faster than a DA9
Nice to see another some what local. Sounds like you have a decent platform to start. If the motor runs ok then I would probably freshen up the suspension first. Check the brakes and do some new bushings and a drop if you don’t have one
that is my plan for starters. I figure I might as well wait tyill I can put some performance goodies on it tho. my susdpensioj is mush and in need of a set of coil overs
A nice new suspension is always good. What are you thinking about getting and what is on there now? I’m about to update mine soon too. Can’t wait.
