Hey thanks for all the feedback! Im glad people are liking my car! I’ve put so much time and work into it, it’s nice seeing people like it!
Hey Tina thanks! I wouldnt have made the car this far without you!
Oh yeah for sure!
sweet teg
i normally don’t like paint matched moldings or rpf1’s.
but for some reason i’m liking them both on your car. nice color too. looks great
good job, man
Well had a bit of trouble Ive got a good feeling its my fuel pump. its not starting, and its not getting fuel, and the pumps not priming, i replaced the mfr and the its still not starting. So I dont know what to do. any ideas?
check fuses and wiring related to the MFR.
Clean teggy BTW:up:
same thing you do when you suspect any fault. isolate. put 12v and ground directly to the pump connector. if it still doesn’t work, it’s the pump.
[QUOTE=BLKACK1;2216608]check fuses and wiring related to the MFR.
Clean teggy BTW:up:[/QUOTE]
Hey thanks! I’ve been reading your thread for a long time! Lots of inspiration!
Okay so put power to the tank wiring and the pump works so I’m lost. Any ideas?
check your grounds.
do you hear anything from the MFR when in the II position?
no the mfr is silent. and i checked the power coming from the mfr to the tank and it has power so im not sure what to do. is it any possibly it is the pump even though it works?
Some pics of the tank pulling.
Tank out!
Dirty tank.
pump
Coming together well man,keep up the good work.
so you have power to the pump but it won’t come on?
and you put power and ground to the pump and it worked?
if that’s correct, it must be a bad ground. that’s assuming that when you checked for power to the pump, you supplied a separate ground through a light tester or multimeter
if you have power at the connector with a separate ground, try checking for power AND ground at the connector
sweet teggy man. Very clean. Love the Jaspar green.
Jasper Green is gorgeous!!! I didn’t like it at first but its complimentary to the lines of the integra and color matched mouldings and side mirrors just give you more jasper to look at!!!
Yeah tomorrow I’m going to check grounds for the teg. See if anything sticks out as unusual. Let you guys know what happens.
Ordered a walbro 255 fuel pump. Thought tanks out might as well do it, since if wanted to do it for a while.
just use a test light. first check for power at the connector. if you have power there, then use it to check for continuity
I have power at the plug just need to check it for continuity. Thanks for all the help!
then it’s almost certainly a ground issue. try putting the ground of the test lamp to the ground terminal on the connector. if it doesn’t light up, it’s a problem with the ground side.
if it does, you have a poor connection at the pump connector
