my LS special
yeah took the ls to the track… and ran a 15.3 at 91mph… is that right is it suppose to run faster… i have a jdm b18a with the short geared trans ys1 i think with stage 3 clutch master clutch fidanza 9lb flywheel… apexi n1 exhaust and gutted interior… and intake… and a short shifter with falken azenis at 18 psi… o with a 2.1 0-60
not bad at all…
which track did you run at?
byron… it was the test and tune thing with UTI and like srt club vs mustang club or somthing…
If you inflate your tires to a normal 35 psi or so you will see better 60’ times. at 18 psi your tires are underinflated and they cup in the center giving you less of a contact patch than running 35psi, which means less rubber available for traction. the only time it is beneficial to experiment with tire pressure is if you are running a full race slick.
yes, the announcer makes fun of people who have street tires and deflate their tire pressure. He said that you’re only losing contact.
