Okay so I think I am going to go ahead and get this set
Strut tower bar- Neuspeed
Lower control arms- The billet by BWR
Shocks- Koni yellows
Coilover sleves- Ground Control (of course!)
My questions are
- If I do not want to be “slammed” but Kinda low what GC springs should I get?
- with the GC springs what is different about the limited edition sleves?
- With all of these products can I just install them or will I need to make any modification and or change anything else out on the car when putting these in?
Any suggestions or advice about getting other suspension parts that would be a good idea too add or just your two cents, would be greatly appreciated
Thanks
I bought the full ES bushing kit and had that installed the same time as struts/coilovers.From my research,alot of guys do the same thing.My fear was spending $500 plus on a setup, only to have the car still feeling ‘‘loose’’ from the all the old bushings.Everything was replaced and i think it was $150 well spent.The car is tight and stiff like you wouldnt believe.I dont regret it one bit.However, if your taking everything to a shop for install they will definetly ass rape you on pricing to put the bushings in.I was qouted an average of $600-800.If its something within your mechanical skill set I would definetly buy the kit and never look back.my 0.02 hope it helps a little.
Thanks man, I Know I can change them if I try. Are all the kits the same or are there some I should stay away from?
