Coke depends how you drive man, i have the same bars for rear top and bottom. But i didnt face it like that how u did in the rear to me thats wrong or at leasts it get in the way more.
Anyway the front and tie bar are not megan becoz idiot ran out. But i been using all 4 bars no problem. As far as rubbing ur tranny tip i just grind into it a lil to give room clearance. I am much lower than you and that tennis ball probably hit if u throw it under. i would say a good 3 1/4 inch clearance for me as i am 1.8 inch drop.
I been driving with it on for 4 yrs. Only 2 times of 4 yrs i hit dead animal or lil stuff on ground while driving and not seeing at night and all it does it put it back an angle of 1 inch if not less. when i get home i pressure blast it and then jackstand it and adjust it back.
I am planning to go homedepot and buy 1 inch solid metal bars and fabricate my own using the megan bracket or some sort. Believe the more solid it is the beter in corner no flexing of the bars PERIOD.
the megan or cheap ebay no names are hollow inside the center as u can see. But will work better then not having it. and i got mines 4yrs ago on ebay $89 shipped wow u got $155
edit: My rear lower tiebar gap from bar to swaybar is 12mm-14mm apart only as i have upgraded anti swaybar too…
Also the front upper bar if use washes you may be able to clear enough just to pass from removing anything from intake manifold as thats what i did.
For me the rubbing sound was the tranny tip was too close or rubbing the bar in the lower front or if after u hit something it moves the angle. grind down that spot or tranny spot. its just dead weight.
and damn u have too much clearance on that bar coz on my lower front tiebar its only 1 inch away from the header downpipe. urs hella far thats bad but for mines being close it act as a brace shield to not bend my downpipe if i hit hard.
Shoot my car was stolen before with this bar on and at the impound they fucking use my lowertie bar to sit on bricks as it was missing tires.
better yet here are 2 photos i just took with my nokia sorry for darkness but u see what i mean closer and more tight then urs.
i never have problems rubbing going over speedbumps normal.
u may corner better than without and also on those shitty falken 512ez or whatever it worthless as i know it is coz i own them before. I know how the pattern looks trust me u will agree too it is lmao.
i have full poly black bushing 19in anti sway bars tokico 5 way adjustables on H&R 1.8inch drop and with those tire its bullshit. I mean it will grip but dont expect better. I even had skunk2 500lbs springs coilover all around on my last set before H&R. the skunk2 helped a lil but if u have onl the bars and lower with those shit tires ur cornering isnt much better then me…
