i just had a exedy clutch and flywheel installed and now when i try to start the car it turns slow untill it catches before i had the clutch installed the car started fine the shop that put the clutch in said it my starter but it was fine before they touched my car and the starter turns so slow my negitive battery cable starts to burn does anybody have an idea of whats causing this
:mad:
Maybe some wires got shorted-out. It’s been a muggy/humid day in the East Coast, so you might want to double-check your electrical connections. Inspect and clean them thoroughly. And see if the problem still there. Also, you might want to check and make sure the bolts weren’t juggled loose or something.
Regards,
Oz
double check the ground connections also cause the may have over/under tightened the and this could also cause a sluggish start condition
