My sunroof is broke
it doesn’t open could it just be the wiring
maybe, but it could also be the motor.
Could also be the switch. At about 130k my switch started to get dirty and would work only sometimes. Eventually I had it replaced but then learned I could have just taken it out and cleaned the metal contacts with alcohol on a Q-Tip or something (someone verify this?). I’d probably check that first if I were you since it will be the cheapest and easiest fix. HTH
Ben
cool thanks
Originally posted by ryuyszh
[B]Could also be the switch. At about 130k my switch started to get dirty and would work only sometimes. Eventually I had it replaced but then learned I could have just taken it out and cleaned the metal contacts with alcohol on a Q-Tip or something (someone verify this?). I’d probably check that first if I were you since it will be the cheapest and easiest fix. HTH
Ben [/B]
Yes, rubbing alcohol (97 cents at walmart) and a Q-tip will work fine for cleaning any electrical contacts. Just pop the switch off and locate the little connections, clean, let dry, and reconnect.
If this doesn’t help your problem, you’re looking at removing the headliner and checking the wiring and motor up there.
~Eric
My fuse was bad, Try checking that too.
Mike
