Since I own my car(about 2 weeks), I had difficulty to start it twice. I had to turn the key about 4 or 5 time before my teg get started. It happened tonight and some days ago… Most of the time I have no problem with it. Any idea, why ? Any of you had the same problem?
Does it turn over at all? I am having a similar problem right now, and it is my ignition coil … it is most likely either your coil, or the distributor bearing (if it is the bearing you will have a grinding/squealing noise from the distributor).
My teg did what you described a few times, and now it won’t start at all, although it turns over … just won’t catch (no spark).
