My untuned db1
Hey guys, check this video out. it is of my 90 ls 4dr. Untuned and running under a b16 map even though it is a b20 because that was the only map that was gettin the car to run.
Let me know what you guys think.
http://videos.streetfire.net/search/integra/0/d9cbe4b9-361b-47a7-8599-98a600f7bc5c.htm
i would say that is pretty terrible for 8psi? car looks good though.
car looks good. get it tuned right though. a b20 on 8 psi should be a little more impressive. Of course it also sounds like you were short shifting.
how would you say that is terrible? if you look at any real 1/4 mile footage from the side it looks slow as balls even though the car is really going pretty fast.
yes but I was also going by sound. he’s not even running it all the way through each gear. probably because of the bad tune he said he had.
you guys should check out this other video on streetfire. Just type in b20 or db1 and look for a race against an evo and remember this is with the bad tune and i mean bad. I have a b20 with stock internals and no vtec and the map on my ecu is from a b16vtec because that is the only thing that is keepin the car runnin. both videos is with the b16 map. I should be getting it tuned in the next month or so. The ecu is zdyne so not too many people know how to tune it around my area.
:fuckrace:
Video looks gay…
I can keep up with a stock evo and Im not even turbo’ed yet…
Get a tune or get another ecu thats chipped to your specific needs. Dont want to see a thread from you later on down the line…" my motor blew…"
:corn:
I don’t think the evo was even trying.
wheres the pssttt sound?
HURRAY 4 4-DOOR INTEGRAS!!!
-this vid will def give me inspiration
BTW b20 is that comparable 2 a GSR or which 1 is faster?
I would say GSR overall but if u talking about block wise i’d go with b20/VTEC
gives u good tq.
there is a video on streetfire of my db1 it’s white and black racing a wrx on 15psi and i was only running 6psi but you just put in integra or wrx it shoul be 1 of the first ones
