Need a source for Volk Wheel Hubcentric Rings
Hi Guys,
I have an issue with my Volk GTP’s (Specs: size 17X7, bolt pattern 4X100), on the Highway I get vibration, I took my car to an alignment place, got a an alignment front and rear, wheel’s balanced, and that didn’t fix the issue, I then took it to my mechanic he told me to get hubcentric rings, because my axles are good, tires are great. I’ve had the wheel for about almost a year, and when I first bought them I tried to use hubcentrings rings but the wheels wouldn’t fit over them the rings were too big. I’ve searched everywhere to find some hubcentric rings for Volks. For everyone here with volks, where did you guys get your hubcentric rings.
you should NEVER ride on wheels without a hubcentric ring.
lots of places online sell hubcentric rings, even places like tirerack.com…what you need to do is find out from volk (hopefully you can find a site with this info) what the hub bore of your wheel is. it has to be exact and to the millimeter. then you’ll be able to order rings by giving that data - they’ll know your hub size by your car.
if you can’t find anyone and get frustrated let me know via email and i’ll see what i can do for you.
Well the wheel offset is +44. Its for a 92 Integra GS-R. If you can find any please let me know thanks buddy.
Whatever you do, don’t do a Google search to find your solution. :roll:
Anyway, here’s the place that will make a custom set of rings for you ( :up:), just provide the measurements. I have a set from them for my TE37s (only came with 2, though) and they are pretty nice and decent quality. I don’t have the measurements though.
I’ve been doing it all day, I still don’t know the measurements of the Centerbore for the rims.
I’ve got all the other details:
Rim size: 17X7
bolt pattern: 4X100
Offset: +44MM
BackSpace: 28MM
Integra Hub Bore: 56.1MM
but what is the Centerbore (wheelbore) for the GTP’s. Is there some sort of formula I can use to figure it out rather then removing the rim and measure a non accurate reading.
If you can find someplace that sells the rims, they might be able to tell you what rings you need. Otherwise, get some calipers and measure.
You might also try 1010 Tires.com in BC Canada. I just told them what I had and they sent me the right rings.
I did, and they told me they don’t know any specs on Volks.
Salespeople usually know jack all. I called them also, they ask for the outer dimension of the rim to figure out the Hub Ring I require.
Ebay,there are 10 set s on there right now
Hey Schu the problem with the sets on ebay is when I ask the seller what I require (for the specs I’ve provided above). They can’t seem to figure out the Centerbore of the wheel. That is my issue, and this info should be available by all so called volk wheel reps.
After a much awaited answer from MackinIndustries. I finally got what seems to be a fishy answer. I’m trying to search for that part #, cannot find it anywhere on Ray’s Engineering site, I have emailed their distributors and I am waiting to hear from them. Plus no companies such as 1010Tires, Eurosport Garage, PrestigeWheel offer a 65MM outter bore. I have emailed all these companies to find out whether they can make it. I’ll keep you guys posted on what happens.
>-----Original Message-----
>From: Li Kwan [mailto:lguan@mail.mackinindustries.com]
>Sent: Thursday, August 05, 2004 1:12 PM
>To: Paul Mann
>Subject: RE: FWD: Hubcentric rings for Volk GTP on 92 Acura Integra GS-R
part# W65/56
---------- Original Message ----------------------------------
Date: Thu, 5 Aug 2004 13:10:13 -0400
>Is there an Product # that I can refer to when I talk to your distributor JRP?
>Thanks,
>Paul
>Sent: Thursday, August 05, 2004 1:09 PM
>To: Paul Mann
>Sorry we dont sell to the public
>From: “Paul Mann” <pmann@exitrealty.com>
>Date: Thu, 5 Aug 2004 13:05:59 -0400
>>thank you now do you have a price for me shipped to 9 Soaring Rock Court, Brampton, ON, L6R 3G7. Thanks again.
>>Paul
>>Sent: Thursday, August 05, 2004 1:01 PM
>>To: Paul Mann
>>the size you need is >>
>>Date: Thu, 5 Aug 2004 12:24:22 -0400
>>>Also I’ve called one of your distributors:
>>>Johnston Research
>>>6985 Davand Drive #11N12
>>>Mississauga, ON L5T 1Y6
>>>(905) 564-8805
>>>www.jrponline.com
>>>They told me to measure by hand the centerbore. I don’t want to have an inaccurate reading. Considering you have rights to deal with Volks, you should have that information handy.
>>>Rim size: 17X7
>>>bolt pattern: 4X100
>>>Offset: +44MM
>>>BackSpace: 28MM
>>>Rim Centerbore: ?? unknown
>>>with all the information I provided, please send me a quote for the centering rings a.s.a.p. Thanks.
>>>Paul
>>>Sent: Thursday, August 05, 2004 12:04 PM
>>>To: Paul Mann
>>>Subject: Re: FWD: Hubcentric rings for Volk GTP on 92 Acura Integra GS-R
>>>You can purchase hub rings at any volk dealer.
>>>www.mackinindustries.com
>>>From: "Product Info " <productinfo@mackinindustries.com>
>>>Reply-To: <productinfo@mackinindustries.com>
>>>Date: Thu, 5 Aug 2004 02:06:50 -0400
>>>>Date: Wed, 4 Aug 2004 13:44:45 -0400
>>>>Hello,
>>>> I am having some trouble finding some Hubcentric Rings for my Volk GTP wheels (rims size: 17X7 bolt pattern: 4X100 Offset: +44). I drive a 92 Acura Integra GS-R. Could you let me know pricing for hubcentric rings for these rims.
>>>>Thanks,
>>>>Paul Mann
i have NO understanding as to why rays engineering/volk doesn’t put this information on the web. i’m not a volk distributor so i don’t have more product information for those wheels.
This reminds me. Before I put on my TE37’s I need to get some of these.
So what’s with the POLY-CARBONATE rings? Like these on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7913921512&category=42614 Compared to metal ones that you could have someone cut out on a lathe?
LOL. If your hubcentric rings are rattling or showing signs of wear, they are not doing their job. You could probably lathe these yourself too if you could get some of the material - I have done various plastics on a lathe before.
He doesn’t carry any rings for Volk Rims.
